Hydraulic Pump for lift/tilt cylinders not turning on
Hello,
I can't figure out where I lost connection. I might have snagged a wire that runs along the bottom of chassis.
If I'm correct it's a (blue/red) wire. I don't see anywhere the wire is damaged however.
If anyone knows a way to jumper this to engage the pump, please let me know so I can narrow down my search.
******update: pump runs and controls work when I force the main contact closed
Thanks for reading!
John
  • Posted 29 May 2025 01:24
  • Modified 29 May 2025 01:33 by poster
  • By john_johnson
  • joined 18 May'21 - 20 messages
miami, florida
Someone may have bypassed the Curtis since single wire. the unit would have a harness that went to it if you want to bypass the Curtis just
Put wire from terminal 6 on terminal 8 of the interrupt
That bypasses it someone may have had an issue with the interrupt and ran wire to bypass
And did not know which wire to jump
  • Posted 29 May 2025 02:53
  • By John_Bradley
  • joined 10 Aug'22 - 268 messages
Jb69
Glad you got it figured out !
  • Posted 29 May 2025 02:47
  • By John_Bradley
Jb69
Thanks for the response- it was the red/blue wire. I ran a temporary wire from the solenoid to the Curtis controller because I'm too aggravated to pull the battery again today lol.
  • Posted 29 May 2025 02:27
  • By john_johnson
miami, florida
If it is an older unit there may be a Curtis interrupt under the floor plate if so you can jump around it if you have one let me know and I can tell you which wires to jump to bypass
  • Posted 29 May 2025 02:22
  • Modified 29 May 2025 02:23 by poster
  • By John_Bradley
Jb69
You should have positive voltage on one wire at all hyd switches wire number 10 ,I believe. the voltage goes to card as switch engages the card sends a negative to contactor to close the pump motor contactor. inside of the card the voltage of battery is checked ,if battery is charged the card will initiate a negative that negative goes to contactor to close it ,that brings in pump motor first check voltage at contactor it should be battery volts on both wires without engaging switch I am assuming that battery is fully charged if not the card will not allow negative to go to contactor it is a safety to insure you charge battery
  • Posted 29 May 2025 01:46
  • By John_Bradley
Jb69
Oxford Ct, United States
Columbus, United States
UN Forklift FD30T-NJM1
Toyota 3FD100
edition #1257 - 20 November 2025
