Rotary exhauster
I have been working on lifts for over 40 years and never heard of a rotary exhauster. What the heck does it do??
  • Posted 1 Mar 2025 07:25
  • By JayR
  • joined 10 Nov'15 - 38 messages
Jay,
The rotary exhauster is used to provide vacuum for vehicle brake system. This is mounted on the right side of the engine as you sit in the seat. I guess you have a Perkins engine?
Engines that are diagnosed with excessive crankcase blow-by must first have the rotary exhauster removed from the engine and the engine
run for this diagnosis to be valid. A brake booster diaphragm failure may also cause the rotary exhauster front seal to be pushed out causing
crankcase pressurization. Good Luck
  • Posted 4 Mar 2025 00:11
  • By Fishmech
  • Virginia, United States
Nagano NUZ090D
SMV (Konecranes) 33-1200C
