Motor Temp Fault Code 24 and 31
Hi I have a '22 yale center rider. We are seeing fault codes 24 and 31 Motor Temperat. 00530h #24 45`C, do we know what these are?
  • Posted 25 Feb 2025 00:27
  • By joel_s
  • joined 12 Jun'19 - 2 messages
  • Oregon, United States
Joel,
Need to verify model number. Make sure the battery is fully charged, and the fluid level is correct. Low voltage will cause heated operation in all systems. The motor temp sensor may have failed or failed electrical connection. Make sure all connections at the motor are clean and tight. Do the same for the controller. Good Luck
  • Posted 25 Feb 2025 23:17
  • By Fishmech
  • Virginia, United States
Esie Cortez Esie Cortez
