Error code
My hyster 3.5tx have error codes are C005, C007, C015 what happened for my forklift?
  • Posted 25 Feb 2025 00:18
  • By Pairoj2521
  • joined 25 Feb'25 - 1 message
  • Thailand
Pairoj
Pairoj,
If the lift has a mini lever module, need to verify proper operation. Could also be lower hydraulic pressure due to failed pressure relief valve or pump. Pressure relief valve may need to be adjusted. Make sure all electrical harness connections have been completed. Good Luck.
  • Posted 25 Feb 2025 22:56
  • By Fishmech
  • Virginia, United States
Terberg YT220
SMV (Konecranes) 16-1200B
Sue Tomic Sue Tomic
