Unit Won’t crank code d000 showing on cluster
I have a hyster h60xt (serial#A380v08699t) that won't crank over. Originally the battery was dead test battery and found it was junk. Put new battery on but as soon the ignition goes on the cluster beeps and set code d000 and the unit won't do anything. All fuses look good, jumped starter relay and the unit starts up but no functions are available and it won't shift forward or reverse.
  • Posted 4 Dec 2024 02:02
  • By Gustavo_Alonso
  • joined 19 Jun'24 - 3 messages
HELLO GUSTAVO
HOW DID YOU SOLVE THE PROBLEM?
I HAVE A YALE GLP050MX FORKLIFT WITH THE SAME PROBLEM YOU DESCRIBE. THE CLUSTER CODE IS D000.
COULD YOU SHARE WITH ME HOW YOU SOLVED YOUR PROBLEM?
I WOULD APPRECIATE ANY INFORMATION.
  • Posted 29 Aug 2025 05:01
  • By MANUEL_H
  • joined 29 Aug'25 - 1 message
  • MEXICO, Mexico
MHS
Yes, I second this also if the truck powers on you can connect to it with PCST and go under truck information and check the engine type. Most the time it will show it has a diesel but really it has a Lp. Note they are also notorious for throwing a speed sensor code and there is a jumper installed in the connector and where the sensor would go is plugged off. Hope this helps!
  • Posted 13 Dec 2024 03:22
  • By Slim99
  • joined 13 Dec'24 - 5 messages
hello friends!
The Hyster XT and Yale MX, they have a problem with the lack of battery power, probably the VCU module file has a corrupt CDF file
  • Posted 13 Dec 2024 03:18
  • By Tecmanuais
  • joined 30 Jan'18 - 2 messages
  • RS, Brazil
tecmanuais@yahoo.com.br
Skype:hyster.brasil
claudio
These units are also notorious for having a scrambled CDF file in it after a battery replacement. If you can connect to the unit and check under the truck information you can look to see what kind of engine. 9 times out of 10 it will say it has a diesel in it not a LP if that is the case. Normally when this happens the unit will start and run but will not accelerate due to a speed sensor code. It is worth a shot just to see what happens.
  • Posted 13 Dec 2024 00:41
  • By Slim99
Gus,
Code is for tilt sensor. Check sensor, wire harness and connectors. If you have a sister truck swap sensor. Not sure this is the start problem. This should prevent transmission engagement and hydraulic operation. Good Luck.
  • Posted 10 Dec 2024 00:30
  • By Fishmech
  • Virginia, United States
Libiao Robotics
Mobicon 2T
Maxlion FB25LI
