Bt mover lpe200 stays on, heat up contactor
Hello friends, I have a problem with bt lpe200 that I can't find the problem. What is actually happening is that the mover does not turn off by itself after a while as it should happen, this causes the contactor to heat up and is accompanied by several errors codes , what could be the problem?
  • Posted 11 Nov 2024 06:26
  • By Shimi_Coco
  • joined 16 May'24 - 3 messages
  • Israel
Factory Cat MICROMAG20D
Elwell-Parker ESI500-36
