My yale forlklift contactor is shooting twice
Hi Good day
Pls I need help on my yale forlklift when opening (ON) the contactor is shooting twice, and won't move or lift with error code of 9024. have tried all my possible best on this forlklift pls help
Model number:ERC25VG MWB V2735
Year of manufacture: 2014
Quick response will be greatly appreciated thanks
  • Posted 23 Sep 2024 01:53
  • By AYODEJISAM
  • joined 22 Sep'24 - 3 messages
  • Nigeria
AYODEJISAMUELADEOLA
Thank you @fishmech
  • Posted 24 Sep 2024 14:03
  • By AYODEJISAM
  • Nigeria
AYODEJISAMUELADEOLA
Ayodejisam,
The code is for a failed controller. This could be bad wiring from the controller to the motor or controller is bad. Complete the following checks.
Verify the following:
Check the traction motor to controller power cable connections making sure they are secure.
Verify the cables are not rubbed or chaffed and shorting to the frame, etc.
Check the motor case to terminals for shorts and for shorts between the UVW terminals.
Switch the main controller wire harness connectors around between the two controllers (traction and pump) and cycle the key switch.
If the code remains the same (with the traction circuit) there is still a short somewhere that has not been located in the traction circuit.
If the code changes to the pump circuit, the traction controller is defective and needs to be replaced.
  • Posted 23 Sep 2024 22:20
  • By Fishmech
  • Virginia, United States
Oxford Ct, United States
Esie Cortez Esie Cortez
SMV (Konecranes) 16-1200C
Komatsu FD25T17
