Steer Pot
I have a rc5500 that fails steer pot calibration. I put a new one on and got the same results. If you go to steer pot values it reads correctly 90 degrees 0 degrees and -90 degrees when you cycle through the steering also the voltage is correct according to the manual but it will fail every attempt at calibration on the last step when you go to center steering am I missing something? The pot is slotted for adjustment but the book says nothing about adjusting it. Also throws no codes. The truck does not drive right when you hit full lock left or right. If you slowly turn full right it will stop turning right and go left same when turning left I know that part is because of the steer pot controlling the drive motors.
  • Posted 31 Aug 2024 09:45
  • By Darin_Lewis
  • joined 31 Aug'24 - 1 message
  • Arkansas, United States
Rusty Bob
Greetings, I have the same problem with the steering, it doesn't indicate a fault, only the turn is made to the right and the traction is reversed to the left. Do you have the solution?
  • Posted 13 Mar 2025 06:37
  • By Dy4cking
  • joined 13 Mar'25 - 1 message
  • Mexico
Are you trying to calibrate the original pot or did you replace it
  • Posted 5 Sep 2024 00:33
  • By Triggs
Komatsu FD25T17
Elwell-Parker ESI500-36
Oxford Ct, United States
Komatsu FD25T17
Esie Cortez Esie Cortez
