Reach and retract cushioning inoperable
I have a crown reach truck, the reach does not cushion in either direction, another truck identical will cushion, slow down the reach extend and slow down the retract a few inches from the end of travel, the truck I am working on will not cushion and will make a violent smash on both reach and retract.
I've tried calibrating the reach sensor, and adjusting the cushioning but nothing changed, any ideas would be greatly appreciated.
  • Posted 9 Aug 2024 09:20
  • By Curtis
  • joined 9 Aug'24 - 1 message
Ethan
You can adjust the cushion settings in the Performace Settings menu, just like how you can set speeds. 0 is no cushion and 9 is max. Id recommend making all the performace settimgs identical to the other RM you have to ensure it is working the same.
  • Posted 23 Aug 2024 01:07
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 223 messages
  • Wisconsin, United States
Kai von Berg Kai von Berg
Komatsu FD25T17
Toyota 02-2TD20
Noblelift
