DTC 520317-2
Have this troublcode but cannot find in my manual. Can anlet me know what this is. Displays code with message to apply park brake
  • Posted 2 Aug 2024 08:21
  • By Roy_Baumeister
  • joined 9 Aug'23 - 9 messages
  • British Columbia, Canada
Thank you very much. Was pretty sure it was trans code just didn't know what for.
  • Posted 6 Aug 2024 00:28
  • By Roy_Baumeister
Roy,
This code is for the transmission. Transmission input shaft speed pulse erratic, intermittent, or incorrect. Need to verify the connection of the sensor and harness. The trans has three sensors installed. Looking at the part numbers none are interchangeable. I have seen the trans harness fail. Make sure to check everything. Good Luck.
  • Posted 5 Aug 2024 22:59
  • By Fishmech
  • Virginia, United States
Hyster
Sue Tomic Sue Tomic
