Overheating
Hi, Linde H40D-02 H2X394D52718 2013 3250 hrs
Truck gets hot after 15 mins, it has the 2.0 vw engine,
Have installed new water pump & radiator is clean, there's No thermostat in the housing not sure if there's ever been one,
it's an open cab so no cab heater, top pipe to the radiator gets very hot & there is flow from the top of the radiator pipe back to the expansion tank, not sure what to try next, everything is spotless no dirt in the expansion tank ?
  • Posted 2 Jun 2024 07:42
  • By LindeJP
  • joined 2 Jun'24 - 1 message
  • United Kingdom
J P
I think you don't need the thermostat, you could eliminate it. But the source of the problem may be in the water pump. Those pumps usually break and leak liquid, is this your case?
  • Posted 6 Jun 2024 21:56
  • By Koldo_Martinez
  • joined 11 Mar'23 - 15 messages
  • Spain
Thanks all!
It needs a thermostat fitting it will overheat without one and if left for too long without blow the head gasket
  • Posted 6 Jun 2024 18:29
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Aichi SR10C1SM
