Error code 5.180
Hi, does anyone know that this code means on a BT LPE-200 ?
Unit only has slower speed. Other than that all other functions are normal.
Code displayed, is 5.180
Thanks!
  • Posted 24 May 2024 04:14
  • Modified 24 May 2024 04:14 by poster
  • By s_k_
  • joined 25 Jun'18 - 12 messages
Komatsu, and Crown, experienced. Let me know what I can help with!
no worries, thanks for letting me know :)
  • Posted 27 May 2024 07:14
  • By andrew_k
  • joined 17 Mar'07 - 337 messages
  • England, United Kingdom
Thanks a million andrew_k. That led me to the steer angle sensor. It was indeed loose, damaged at the mount. You're a gentleman.
  • Posted 25 May 2024 22:53
  • By s_k_
Not sure if the codes the same but on an SWE120 that code means Steering angle signal is outside the valid range.
  • Posted 24 May 2024 06:25
  • By andrew_k
MAXAM Tire, Inc.
