Need help 1987 TCM FCG20N6
Hi guys I have a 1987 TCM FCG20N6.I was replacing the battery & accidently connected it backwards.After just having a new starter put in. Soon as I connected I noticed smoke coming from the starter area.I disconnected it right away about 5 seconds. Then reconnected the battery correctly. But am getting no gauges or horn or no crank happening. Is there a main fuse to check? Or did I most likely fry the starter? If I did fry the starter would that stop other electrical items from working like the horn gauges etc?
  • Posted 6 Apr 2024 06:10
  • By onestepx
  • joined 6 Apr'24 - 1 message
I would check by the battery or starter on the positive side you probably burned what's called fuseable link it is a small wire that will break inside before you burn the wiring to the truck. When this happens you will get no power at all to the truck.
  • Posted 7 Apr 2024 12:50
  • By Scott_
Scott
On some trucks not 100% sure with TCM there are small wires to the positive battery terminal with spade conections, this is fuse wire.
  • Posted 6 Apr 2024 07:56
  • Modified 6 Apr 2024 07:57 by poster
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
Crown SX3030TT4250
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
VETTER Industrie GmbH
