Access 1
Arrow buttons went bad on access1, got a renewed access to install and replace bad one, lift just alarms. and buttons do nothing.
  • Posted 12 Mar 2024 02:51
  • By LittleJon
  • joined 6 Dec'22 - 22 messages
  • Arkansas, United States
Ok, thanks
  • Posted 12 Mar 2024 03:51
  • By LittleJon
I would update the whole truck to the latest software.
  • Posted 12 Mar 2024 03:46
  • By DyslexicNerd_01
  • Wisconsin, United States
Yeah, up and right arrow work, got the PN 149572-001-20 for the access 1 software, so we would need to update the new access one with that software ?
  • Posted 12 Mar 2024 03:43
  • By LittleJon
You can check the version in the service menu but if the buttons don't work you would need a computer with the correct software and connector.
Most of the time modules come with no software installed as they don't know what truck it will end up in. Updating software should solve your issue.
  • Posted 12 Mar 2024 03:20
Not to my knowledge, how would you check the ver of software on the access1, and I take it you will need a computer with the update and a usb to connector to update the module?
  • Posted 12 Mar 2024 03:16
  • By LittleJon
Did you update the software on the lift? All the modules need the same version of software. I have also run into bad renewed access modules before too.
  • Posted 12 Mar 2024 02:57
  • Modified 12 Mar 2024 02:58 by poster
Hawker Powersource, Inc.
