control valve
control valve is not working on "mast down ". All functions are working as suppose to.Mast UP is good ,but down is not being able to lower it.Initially spool was damaged and bypassing (still working), after re-chroming and resizing spool
customer reinstall valve and now doesn't work. Electrical signal is going to coils and coils are ok. Is there pressure sensor some were ? I can't get my hands on hyd. schematic. Any help will be much appriciated.
Thanks
Lubo
  • Posted 12 Mar 2024 01:47
  • By Lubo_Blazek
  • joined 12 Mar'24 - 2 messages
  • British Columbia, Canada
Tkanks we will check on this tomorrow morning.
  • Posted 15 Mar 2024 10:11
  • By Lubo_Blazek
Is the mast elevated? If so and it won't lower it sounds like it is a problem with the velocity fuse which is located at the base of the cylinder behind the hose fitting. If the mast in elevated and won't come down then you will have to jack up the mast to take the pressure off the cylinders and it should come down.
  • Posted 15 Mar 2024 09:52
  • By duodeluxe
  • United States
duodeluxe
Manitou M50-4
Crown RR5225-30TT321
RAEDER-VOGEL
Manitou M50-4
