Forks drifting down
Hi. Unit is with forks drifting down. Is this the cause of the RVM valve? Finding root cause and only leading to this product.
  • Posted 4 Jan 2024 05:51
  • By JuanitoPanko
  • joined 10 Jun'23 - 12 messages
Thanks for the clarification.
If it isn't leaking oil, then there will be an issue with a couple of valves. For the lift cylinder to drift, oil will need to pass SVH and/or CVL, SPL to get back to the tank.
Probably be logical to inspect those valves for debris.
Follow the hydraulic schematic from SVH to the tank.
  • Posted 5 Jan 2024 06:06
  • Modified 5 Jan 2024 09:08 by poster
  • By Buster_Hymen
  • joined 21 Jan'18 - 14 messages
Lift cylinder drifting down. Unit off.
  • Posted 5 Jan 2024 03:02
  • By JuanitoPanko
Need more information.
Assuming the lift cylinder is drifting down, not the tilt drifting down.
Does it still drift with the unit powered off?
You need to determine if the drift is an electrical or mechanical issue by raising the carriage and powering down.
Don't look for a manual release valve as a RC5500 series does not have one.
  • Posted 4 Jan 2024 08:06
  • Modified 4 Jan 2024 14:15 by poster
  • By Buster_Hymen
Have you checked the manual release valve? This is a black **** on the hydraulic block. Typically that is what causes forks to drift down slowly.
  • Posted 4 Jan 2024 06:31
  • Modified 4 Jan 2024 07:15 by poster
  • By DyslexicNerd_01
  • Wisconsin, United States
UN Forklift FGL18T
Taylor TX330S
USD159,500
UN Forklift FGL18T
Taylor TX330S
USD159,500
