Error code E5304
Hi Guy's,
Having a little problem finding information on fault code E5304.
Any help would be great.
Thanks
  • Posted 25 Oct 2023 10:03
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
forkliftrepairs at dodo dot com dot au
Mrforklift,
Make sure to set the brake pedal travel first before calibrating the sensor. Have tried setting inch pedal without brake, sometime it works and sometimes it does not. Good Luck.
  • Posted 28 Nov 2023 02:23
  • By Fishmech
  • Virginia, United States
im guessing you have te5304 as a code, the T in the display looks werid so isnt always obvious. this code is for the inching pedal being out of range. it will just need to be calibrated.
  • Posted 9 Nov 2023 18:53
  • By Chris_Compton
  • joined 20 May'20 - 5 messages
  • New Zealand
Muncie, IN, United States
