Random no horn or tilt forward
Repaired ground by controller about 3x's
Replaced joystick and battery is new still random horn and forward tilt
Everything else is good
  • Posted 12 Sep 2023 00:37
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Awesome thanks
  • Posted 12 Sep 2023 05:00
  • By Matthew_Reed
The horn runs through the same wire harness. Does the horn switch feel the same as other horn switches? If it doesnt the button won't make a click noise and you know the issue is witht the horn switch. Check the cables for any cut wires. If the horn sometimes goes off randomly the problem should be with the switch or wiring harness, sometimes wires get pinched inside the handle causing problems.
  • Posted 12 Sep 2023 02:55
  • By DyslexicNerd_01
  • Wisconsin, United States
Replaced full handle and recalibrated
Found faulty harnesses going into joystick, were the tilt issue, still don't know about horn, thanks
  • Posted 12 Sep 2023 02:10
  • By Matthew_Reed
Did you replace the full joystick handle or just the tilt pot and horn button? With it randomly going off, you may need to recalibrate the handle in the service menu if not done already.
  • Posted 12 Sep 2023 01:14
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
UN Forklift FD50T-NJB3
Sue Tomic Sue Tomic
