Hydraulic oil reservoir location (replaced hose)
feeling lil dumb but have searched the machine over and cant find oil reservoir to fill after replacing leaking hose...definitely low as will not raise all the way without suction noise
  • Posted 6 Sep 2023 06:44
  • By kingkuality
  • joined 21 May'17 - 61 messages
thank you i was under that cover but probably missed it....thanks again
  • Posted 6 Sep 2023 08:55
  • By kingkuality
  • By kingkuality
Have to pull off the front cover behind the mast. fill cap is on the lower right side if you're standing on the forks. down a little below the tilt cyl.
  • Posted 6 Sep 2023 08:26
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
Nagano NUZ090D
Nagano NUL120-6
Nagano NUZ090D
Nagano NUL120-6
