H50H 4-172 engine removal
Can anyone give a few suggestions on how to remove the Ford 172 gas engine from a H50H ? Disconnect from trans or leave connected?
Thanks
  • Posted 30 Aug 2023 13:44
  • By mac_f
  • joined 14 Sep'12 - 8 messages
  • New South Wales, Australia
Mac,
We usually use oak blocks 8X8 or 12X12. Also they make a stacking blocks made specific for lift support. When you have everything loose and ready to remove the engine, support transmission with a block. This will make removal and installation of the engine easier. Make sure to unbolt torque convertor and pry it back towards the trans. This way you do not dump fluid all over the floor. Good Luck
  • Posted 6 Sep 2023 23:21
  • By Fishmech
  • Virginia, United States
The trans does not require any work, just the engine.
Obviously normal car stands are not strong enough. Can you suggest suitable stands, does hyster have their own and is there a proper lift point for the jacks?
Thanks for your help
  • Posted 6 Sep 2023 16:26
  • By mac_f
Mac,
Most of the time this is decided if the transmission needs work or just the engine. Some techs believe it is easier to split apart after removal and others will separate in lift. Should you pull just the engine, best to put lift on stands to give more room underneath. Good Luck
  • Posted 6 Sep 2023 00:27
  • By Fishmech
UN Forklift FBR25NQC3
Nagano NUL120-6
Nagano NUL120-6
