Transmission fluid leak
I have removed transmission couple times and replaced O-ring and seal. After transmission is installed and engine started, its leaks transmission fluid between the transmission and engine. Replaced O-ring and seal for the second time, everything looks good. The fluid pours out with just the engine started and transmission not engaged. Vent is not plugged. Everything works ok, but leaking. Would the transmission be building up too much pressure or is it some other issue?
  • Posted 24 Apr 2023 03:28
  • By Hubert_Randell
  • joined 24 Apr'23 - 1 message
  • Newfoundland and Labrador, Canada
Manitou M50-4
SMV (Konecranes) 4632CC5
