no start
serial #64598
Engine will not run unless you hold the ignition switch in the start position. I disconnected the excitor wire from the starter and used a remote start switch, the engine will run as long as the ignition switch is in the start position. I have 12 volts to the coil and distributor with key on. I have 12 volts to the lp converter as long as the switch is in start position. Could this possibly be a shutdown system failing?
  • Posted 6 Apr 2023 07:12
  • By Twj65Srj67
  • joined 25 Sep'20 - 4 messages
  • Arkansas, United States
I would check the distributor tac wire if it is broken it will only run in the start circuit. Check from distributor to computer.
  • Posted 8 Apr 2023 08:15
  • Modified 8 Apr 2023 09:32 by poster
  • By Scott_
Scott
SMV (Konecranes) 4632CC5
Terberg YT220
