codes and no traction shut down
Does anyone know if codes are displayed on the console or do I need a handset.
This machine , while operating a short distance shuts down traction and displays a wrench code. Turning off the key and turning back on resets the machine but will shut again when driving.
I removed the top cover and gently tapped the wiring leading to/from the joystick handle at the connections looking for an intermittent issue while driving. Suddenly, when tapping the wires the truck lurched forward into high speed. This happened several times
Has this issue ever occurred w/ anyone else, wiring would seem to a problem but a high speed jolt seems out of the ordinary.
thank you for any advise.
  • Posted 2 Dec 2022 20:11
  • By 7777
thank you
  • Posted 6 Dec 2022 07:05
  • By 7777
thank you
  • By 7777
use up/down arrows to "log", press enter
will show last ***
down arrow E1 or L1 cannot remember ***
my guess fault 331 traction encoder open circuit
  • Posted 4 Dec 2022 20:50
  • By crownie
  • Victoria, Australia
Scroll down and see the error codes, if you can't.
Check the bellow
* Optical switch in control handle
* Drive pot in control handle.
  • Posted 4 Dec 2022 13:46
  • By nadeem_a
  • joined 31 Mar'16 - 3 messages
  • Sindh, Pakistan
Venture421@gmail.com
codes should be displayed on access 1, use arrow buttons to scroll down to events
  • Posted 3 Dec 2022 03:29
  • By JMC1
  • joined 8 Nov'18 - 50 messages
  • Iowa, United States
Airman ENCL045
Maxlion FB30EH
REPOWERTEK Inc
