h100xm l005v0735d fuel shutoff
I am losing power to injection pump fuel shutoff any one know what feeds this ? just the key switch or relays any help much appreciated
  • Posted 21 Sep 2022 04:47
  • By lonnster
  • joined 23 Feb'19 - 11 messages
thank you found a broken wire appreciate the help
  • Posted 5 Oct 2022 01:51
  • By lonnster
One other check, you may need to take apart the connector and inspect all terminal crimps. I have found loose connections in the past.
  • Posted 1 Oct 2022 00:31
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
There should be a relay under dash. There have been multiple problems with these trucks for wiring and ground. Verify all wiring going to solenoid is good. Make sure to pull apart connectors and check for corrosion. Check the resistance of the solenoid, make sure it is not shorted to ground. Good Luck
  • Posted 1 Oct 2022 00:30
  • By garland_m
Hitachi HX64B2
UN Forklift FD30T-NJM1
Sue Tomic Sue Tomic
