Error 177 and 173
Hello to all,
I have Still forklift R20-15, year 2002, sn: 512008017647, buy second hand from an auction / untested and unverified :(
The big problem is code 177, which appears as soon as I start using the forklift.
If I put the ignition on and leave it for a few minutes, I can use the forklift without problems until the evening.
Code 173, appears during the use of the forklift, and manifests itself as it stops working for 2 or 3 seconds, then recovers.
The oil and filter inspection was done recently, and it was found that there was only 5 L in the entire installation.... now I removed all the oil and put 18 L, but the problems persist.
Do you have other ideas, what should I check and test ?
  • Posted 2 Sep 2022 00:39
  • By Dan_Alexander
  • joined 2 Sep'22 - 5 messages
  • Romania
front axcel are two motors , left and right , behind the motors under floor plate you see it. But is really difficult to service it.... better look in pc daignose if sensors correct work.
  • Posted 2 Sep 2022 21:29
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Hi Tr_Doctor,
Thk to reply on my post, where i found i diagram or photo to identify the speed sensors drive? where they are located ?
  • Posted 2 Sep 2022 18:26
  • By Dan_Alexander
  • Romania
possible trouble with speed sensors drive motors , or wiring from sensor to electronics in counterweight.
  • Posted 2 Sep 2022 16:50
  • By tr_doctor
  • Netherlands
Regards
Crown SX3030TT4250
Toyota 02-2TD20
Michel Denis Michel Denis
Crown SX3030TT4250
Toyota 02-2TD20
