Brakes stuck on
Truck tries to drive but feels like brakes are stuck on, No error codes.
Any ideas please
Thanks
  • Posted 20 Jul 2022 03:00
  • By andrew_k
  • joined 17 Mar'07 - 338 messages
  • England, United Kingdom
according to the 393-02 series (not sure but the 392 may be the same) but the brake system uses a brake valve operated by 2 switches. One of those may have been stuck or it could just be out of adjustment just enough to cause an intermittant problem.
I thought it may have been frozen up but 40deg isn't enough to freeze it up.
Plus Linde is fairly adement on having heaters located near switches to keep that from happening. (not all trucks have heaters but quite a few do).
I would double check those switches adjustments, make sure they are not dirty.
  • Posted 24 Jul 2022 07:00
  • Modified 24 Jul 2022 07:02 by poster
Hi Michel. I went back to the truck the following day and it had fixed itself. Im blaming the 40 degrees weather lol. Thanks
  • Posted 23 Jul 2022 20:20
  • By andrew_k
what is you brake presure ???????????
  • Posted 23 Jul 2022 04:33
  • By michel_v
  • noord holland, Netherlands
Komatsu FD25T17
Terberg YT220
