Cranking but wont start
I have a Mitsubishi Fg25N LPG forklift and The thing is that the machine suddenly stoped and its not starting,its cranking but its not starting.what have i noticed its that the fuel injector when I turn the key on its fludding the mixer with gas ,and if I put my finger there where the lpg its entering in the mixer from the injector the engine starts.what might the problem be the injector or some sensor?or the ecm shoul control the injector tonthe right amount of lpg.
  • Posted 9 Apr 2022 09:16
  • By GEORGE_DENES
  • joined 22 Oct'20 - 7 messages
  • Romania
good morning from greece we have the same machine Mitsubishi FG25N with E23 code indication what is the problem ?
thanks
  • Posted 6 May 2022 13:33
  • By giorgos_k
  • joined 10 May'17 - 41 messages
  • Makedonia, Greece
delete
  • Modified 12 May 2022 14:53 by poster
  • By giorgos_k
  • Makedonia, Greece
delete
  • Posted 6 May 2022 13:31
  • Modified 12 May 2022 14:52 by poster
  • By giorgos_k
  • Makedonia, Greece
If you turn the key on and you hear a constant hissing noise coming from the intake its most likely the main injector oring is broken or the assistant injector is stuck open. Its possible the main injector is stuck open but highly unlikely. These are the only two components that allow fuel to enter the throttle body. I highly doubt the vaporizer is the issue. Main injector is the large circular one with an in line fuse. Assistant injector looks like a long 6 sided nut with 2 black wires sticking out the back.
  • Posted 10 Apr 2022 21:24
  • Modified 10 Apr 2022 21:30 by poster
  • By BLey
  • joined 31 Jul'20 - 60 messages
Is their no code showing probably the vaporizer worth checking the assist solenoid that can stick open
  • Posted 10 Apr 2022 18:06
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
I am assuming the truck is using a k21 or 25 engine if so check the propane converter pressure first take out the top plug at the Nikki converter and put a pressure gauge in there and turn the key to on and see if you you are getting 5 psi it should hold steady if keeps getting higher the converter is bad l have seen as much as 8 psi any more and will blow out mixture if OK then look at o ring at main injecter some time it breaks and could cause lpg to blow out mixter if all checks out l believe the body that the main injector sits in is bad there are small valves inside that stick and cause the lpg to blow out the air cleaner must replace complete holder hope this helps
  • Posted 10 Apr 2022 07:42
  • By Scott_
Scott
