110-2 code
Hello I can't seem to find any information on this code. It's a serial number N005V04323F. Runs ok but has an intermittent 110-2 code. Any help is appreciated.
  • Posted 10 Mar 2022 09:13
  • By Greasemonkey
  • joined 10 Mar'22 - 15 messages
Hey thanks! Sounds like it could be a thermostat that's stuck open. Appreciate it!!
  • Posted 14 Mar 2022 23:41
  • By Greasemonkey
Hey Grease,
Since you have a 4.3 GM, I would first check the negative cable going to the block. Make sure it is clean and tight. The code is for engine temp low after warm up. If the ground is good, check temp sensor connector and wires. Did you remove the thermostat? Also make sure your coolant level is correct.
  • Posted 14 Mar 2022 23:02
  • By Fishmech
  • Virginia, United States
Maxlion FD30
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Lift Tek Elecar
Lift Tek Elecar
