Multiple codes
I have this unit and every time I start unit it does something different, either it will give a code E 152 or E 150 and C 68. Some times I can get to the point of entering the code on the key pad but then will not allow any function no matter what function I use, it will immediately show one of those codes.
Please help
  • Posted 24 Feb 2022 06:24
  • By Hunter_Roden
  • joined 24 Feb'22 - 1 message
  • Idaho, United States
Hunter Roden
Check to see if ETAC card in handle has moisture issues. Corrosion on the card will throw random codes. Also check gray cable from etac through handle for damages. There's an updated cable for this issue. Batteries good condition?
  • Posted 25 Feb 2022 23:28
  • By ron_k
  • joined 2 Apr'15 - 124 messages
  • North Dakota, United States
4kliftman
Taylor TT300
Crown CG33P5
