code LL
I have a gs 1930 with the LL code. I did what the troubleshooter said. Locate the red wire with level sensor hooked up. check for 24 volts. No voltage. Ground. continuity good. all the way back to A-5 at the ECM. Says replace ecm. I did and have the same code. I bypassed the level switch. still ground on red wire. I cut the wire at a-5 and added 24 volts. LL code went away while 24v is applied. but 18 code came up. I checket the limit switches at both pothole guards. working perfectly. Someone please help me. this is the only Genie we have and I am stumped.
  • Posted 1 Feb 2022 08:45
  • By JOSEPH_BENNETT
  • joined 1 Feb'22 - 2 messages
  • Louisiana, United States
Joey Bennett
Did you ever figure this out? I have the exact same problem going on.
  • Posted 24 Mar 2025 01:04
  • By bryan_petersen
  • joined 24 Mar'25 - 1 message
  • New Mexico, United States
Bryan petersen
Manitou MH25-4
SMV (Konecranes) 4632CC5
