Hydraulic and drive doesn’t work
Hi,
I have Atlet ums 160. Reach truck
No 5 volt supply. Can't calibrate accel, break and hydraulic (levers). Defected Atc and display are changed.
Someone have experience? Appreciate any help.
  • Posted 18 Jan 2022 08:15
  • By Mure
  • joined 18 Jan'22 - 2 messages
  • Norway
hello ,
did you mange to solve this issue ?
Please explain what you did and what repairs are done, my atlet uns200 is having the same issue.
After start, the hydraulic will be stopped, the display shows "Acceleration failure" and the fault code E48.
  • Posted 23 Aug 2024 14:47
  • By Tibi_Mad
  • joined 23 Aug'24 - 1 message
  • Romania
I changed ATC computer and display because the were damaged. Don't know reason what's happened.
And now I get error code E 49 that's mean something wrong with accel. I get on display hydraulic stopped too. Tried to calibrate accel, break pedal and levers but I get calibration failed.
Find out that I missing 5v supply on the plinth (many pink wires) beside the contactor. Checked wires and it looks good.
  • Posted 21 Jan 2022 07:51
  • By Mure
  • Norway
Hi,
Can you be more specific?
Where you don't have the 5v?
You have any error on the display?
What are the symptoms?
I didn't understand what's with the ATC and display?
  • Posted 20 Jan 2022 16:59
  • By vanoss
  • joined 1 Nov'17 - 43 messages
  • Bihor, Romania
Bolzoni SpA (Group HQ)
