yale electric lift pops fuse immediately when turning key on
model number ERC040AFN36SE076 lift. when turning key switch on it blows fuse immediately and i lose all power. Can't find any stuck contacts and battery seems to not be grounding out. help please
  • Posted 14 Jan 2022 00:48
  • By blakeW
  • joined 3 Dec'21 - 1 message
  • Mississippi, United States
Blake
ERC040AFN is a 4 wheel sitdown 36v counterbalance.
i presume the fuse it is blowing is the control fuse in the fuse panel? then start back probing till you find the short, it's either wiring chaffed and grounding or a bad component or something along those lines.
I highly doubt it's a battery cable, if it is that, you will definitely see sparks and fire and smoke so finding one of those cables shorted should not be too hard. ;o)
  • Posted 17 Jan 2022 10:19
take a very good look at the battery cables.
if one of the cables is cut, has exposed copper, and maintains contact with any metal part of the pallet truck, that would be one reason for blown fuses.
  • Posted 15 Jan 2022 16:48
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Linde C4230TL5
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
