Code E115
Getting an E115 code. replaced the main connector, still getting code. Tested batteries, have 3 that are 6 volts, and one that is 3.2 volts. All 4 batteries are less then a year old. Would that one battery cause the E115 code?
  • Posted 16 Dec 2021 07:25
  • By Digby_ODell
  • joined 16 Dec'21 - 1 message
  • Kansas, United States
E115 - I know this is an old thread, but I just ran into this code again. My experience on these units is that low voltage can throw most fault codes in the book. It's always worth starting with known good voltage. Unit would double click and fault to E115 when you tried any function or bringing the control head down to drive position. On one occasion, I was able to get the contactor to pull in and the horn to honk, but it sounded muted. I replaced the horn, and everything functioned as it should. I didn't dig any deeper to see if the horn had an internal short or...? Just thought I'd throw this out here, since it doesn't mention it as a possible cause in the book. You may also look at this thread for other causes: Raymond 102T-F45L
code 115 is there a fix.
  • Posted 10 Feb 2023 00:20
  • Modified 10 Feb 2023 00:25 by poster
  • By CR500R
  • joined 24 Jan'15 - 15 messages
  • Indiana, United States
Yes the computer wants to see good battery voltage on all 4 battery's l would not replace one battery as the other battery's will fail as all battery's are the same age
  • Posted 17 Dec 2021 14:22
  • By Scott_
Scott
JCB 533-105
UN Forklift FBT20NQZ1
