Problem with the folklift R14
Hello,
My folkloft R14G stops while driving first shows an error S278
then these errors also appear T241, T471
Sometimes this is fixed quickly after switching off and on again, but it often happens that I wait longer than a few hours.
Please help with advice
Thanks in advance
Vsln
  • Posted 26 Nov 2021 02:13
  • By vsln
  • joined 26 Nov'21 - 2 messages
  • Bulgaria
Thanks for the comprehensive answer.
Before taking action, I want to answer the following question.
Is it possible that the error S278 is due to a weak battery ? / my 48 volt battery is well maintained, but it is already 13 years old /, when loaded it drops to 44.5-44 volts.
Thanks
Vesselin
  • Posted 29 Nov 2021 17:28
  • By vsln
  • Bulgaria
Fault S278 = Steering wheel potentiometer error
T241 = Safety signal from steering is off
T471 = Safety controller has cut out traction because of detected error
Check steering wheel potentiometer
  • Posted 29 Nov 2021 10:06
  • By LionKing
  • joined 15 Mar'15 - 24 messages
  • Groningen, Netherlands
d.gruis@home.nl
