Alarm 24 ??
Hi guys
Got an issue with a reach stacker. Comes up with Alarm 24 then you have to manually override the system to get the boom to Tele out and go up and down. Rotator works and locking pins but won't extend
Any thoughts ?
  • Posted 22 Sep 2021 15:27
  • By Andy2577
  • joined 22 Sep'21 - 2 messages
Andy,
Too high of pressure difference between the derricking cylinders at the Piston sides. Verify all wiring at the cylinder valves is good, check all connections. Before using bypass, continue the derricking functions, does the boom start raising again? If not replace the derricking sensor. When was the boom calibrated last? You might want to try that first.
  • Posted 2 Oct 2021 01:47
  • By Fishmech
  • Virginia, United States
Sue Tomic Sue Tomic
Ncn 110TH
Ncn 110TH 2015
Kalmar DRF450-70C5XS
Hawker Powersource, Inc.
