Error/Fault code: T0326
Hi, I have this fault code, this is regarding the forklift "safety relay" right?
Im confuse where is the safety relay for this forklift E26S model.
Please need your inputs.. thank you...
  • Posted 19 Sep 2021 12:13
  • Modified 19 Sep 2021 12:13 by poster
  • By SSTC_Tech
  • joined 18 Aug'13 - 8 messages
  • South Cotabato, Philippines
Hi,
I am not really sure if your truck model is serial E387 or E1276.
Error code T326 means "Safety relay contact is closed although relay is not activated"
The Safety relay is located inside the controller LDC A2, open the cover of the LDC you can see it locating at the corner of the PCB which looks likely a small rectangle box around 30 mm square with the copper-yellow color.
In this case, the contact tips maybe sticky, find the way to clean it or replace the one.
Good luck
  • Posted 20 Sep 2021 16:33
  • Modified 20 Sep 2021 22:56 by poster
  • By Nunanemo
  • joined 24 Mar'19 - 24 messages
  • Viet Nam
Cheers
Nuna - Ho Chi Minh City
Email: dairongservice1973@gmail.com
Website: xenangdairong.com
Ncn 110TH
Ncn 110TH 2015
Manitou M50-4
Hyster
