Error code 299
Has anybody been able to get rid of the unlisted error code 299? or keep from coming back on. It usually comes on every month or so.
  • Posted 10 Sep 2021 01:11
  • By Hector_Correa
  • joined 31 Jul'20 - 4 messages
  • Arizona, United States
Sorry for a late reply, thanks for the info Ill follow up.
  • Posted 13 May 2022 01:11
  • By Hector_Correa
What is the serial number? What software version is installed? When it fails, check for a shorted lift pump motor. My suspicion is that it is either a motor, motor cable or access 2 issue. Have you talked to Crown? I've had several error codes over the years that were not listed and have had to ask Crown tech support to talk with the engineers. Most of them dealt with the system that had event codes in the same sequence.
  • Posted 10 Sep 2021 02:55
  • Modified 11 Sep 2021 12:55 by poster
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
RAEDER-VOGEL
RAEDER-VOGEL
