Drive Wheel Studs Stripping
I am having an issue with stripping the studs on the solid wheel hub studs. I did a brake job and have started to reassemble. I installed the taper bearing nut, although that was difficult I probably have a bad thread and tried chasing but didn't have much success.
My issue is when I tried to torque the wheel hub nuts to 150 lb-ft I started to strip the studs. I tried a new nut but the issue is with the studs. I even pulled off one from the other side and tried retightening but that started to strip as well.
I realize this forklift is old but don't know why the studs would be damaged. Any suggestions before I pull off the wheel again and replace all the studs?
  • Posted 3 Sep 2021 03:04
  • By Rayzsurfer
  • joined 3 Sep'21 - 1 message
  • Arizona, United States
Lift Tek Elecar
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Komatsu FD25T17
Sue Tomic Sue Tomic
