Errors E146 E026 E048 E057
Hi everyone,
We have Jungheinrich ERC 14.
We have some errors - E146 E026 E048 E057.
the symptoms are:
- when moving forward - backward works.
- when cornering - switches off.
Please help us with information about these errors or documentation where we can check them.
Thanks in advance
Kind Regards
  • Posted 25 Aug 2021 18:23
  • By Ivaylo_G
  • joined 25 Aug'21 - 1 message
  • Bulgaria
ERC14 means it is between year 2001-2004
E026: Wire Breakage - Lift Pot
E048: Does Not Match the Steering Type Parameter
E057: No Actual Value Change - Check actual Value transmitter
E0146: Reverse Pedal Switch Error - Broken Wire or Short Circuit in Switch
If it works normally in straight position, most probably your tiller wiring harness has some problem which twist and drop some connection. Check wiring first.
  • Posted 2 Sep 2021 02:47
  • By Addy_MHE
  • joined 9 Jul'13 - 160 messages
  • Sindh, Pakistan
Work Until IDOLS become your RIVALS.
Maxlion FB25LI
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
