hydraulic
main lift slow, other controls seem normal
  • Posted 24 Aug 2021 23:50
  • By keith_l
  • joined 26 Jul'16 - 3 messages
  • Indiana, United States
Keith,
Do you have manual or electric hydraulic control valve. The electric control valve would be controlled by finger switches mounted beside the seat. Manual would have long handles coming out of the dash on the right side. Electric hydraulics could be just a calibration of the mini lever or a failed mini lever. Some models you can swap levers from lift to tilt. To calibrate the mini lever will require access to diagnostics. For the manual hydraulic system, check the valve handle mounting, make sure nothing is loose or missing. I have seen the linkage still in place, but barely moves the valve due to loose linkage.
  • Posted 3 Sep 2021 04:56
  • By Fishmech
  • Virginia, United States
El control hidráulico es manual o electro hidráulico?
  • Posted 27 Aug 2021 02:18
  • By Omar
  • joined 25 Jun'21 - 8 messages
  • Colombia
Omar G
