Won't side shift
Won't side shift accepts calibration, but still not moving coils are good would it be the valve? If it accepts calibration than the pot would be good right?
  • Posted 23 Aug 2021 03:11
  • By Beck
  • joined 26 Mar'21 - 8 messages
  • Arkansas, United States
Beck Merola
I can help you solve the problem. Did you get anywhere with it?
  • Posted 25 Aug 2021 11:57
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Be sure that the Bearings & Sliding Surfaces are properly lubricated.
  • Posted 24 Aug 2021 13:30
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
If it calibrated successfully then the pot is good.
Can you hear the pump motor running when you try and side-shift? If so, is the fluid by passing and going back to tank?
  • Posted 24 Aug 2021 12:42
  • By 1CrownTech
Enforcer FLBAXT25
Taylor TT300
