ERROR C29
Please advise what is this error C29 for and the procedure to remove it
  • Posted 12 Aug 2021 20:19
  • By Isa_Alderazi
  • joined 25 Feb'21 - 10 messages
  • Bahrain
Isa Alderazi
hi.
- Connect the service key to the truck.
- Press switch I while turning the key.
switched on.
- Advance to parameter 25 using II.
- Press switch I; the display blinks.
- To check the old value, press only switch I
one more time.
- To modify the value, press switches II / III. Adjust the
new value by pressing switch I.
- After setting the new value, the display stops flashing.
It is the procedure according to the manual, it is a maintenance code, just change the parameter
  • Posted 16 Aug 2021 13:58
  • By lovelift1990
  • joined 19 Oct'19 - 5 messages
  • Peru
VETTER Industrie GmbH
