Error d
Need help for CAT forklift MC60DSA. it showed error F9 on display and i replaced the transistor now it shows F6 on display.
Any idea what should i check or replace. Thanks
  • Posted 17 Jul 2021 19:59
  • By Addy_MHE
  • joined 9 Jul'13 - 160 messages
  • Sindh, Pakistan
Work Until IDOLS become your RIVALS.
I have found a lot of these to be the harness and pin connection, between the shunt field card and the main logics board.
  • Posted 25 Jul 2021 23:42
  • By ETharp
  • joined 16 Jun'21 - 1 message
it ain't rocket surgery
F9 is a pump shunt field circuit failure.
F6 is a pump circuit failure.
I would check your pump fuse and then make sure your brushes and power cables are good.
On the F6 check the D4P diode for short/failure
On the F9 check the shunt field fuse for open.
  • Posted 20 Jul 2021 21:21
