No Forward or Reverse
I have a linde H35D, I have no forward or reverse, but I can use the lift and then I can get forward and reverse, will drive all the time until shut if off, then no travel until use the lift. I have changed the seat switch.
  • Posted 17 May 2021 21:42
  • By David_Weber
  • joined 17 May'21 - 4 messages
  • Michigan, United States
David Weber
hello , problem can also the accelerator, be sure they are correct. Need software for calibrate.
Also check rpm sensor on starter ring flywheel, input need for drive.
  • Posted 18 May 2021 20:50
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
H2X393B00339, it only had one seat switch
  • Posted 18 May 2021 20:40
  • By David_Weber
David Weber
I did change seat, didn't take care of problem.
  • Posted 18 May 2021 20:37
  • By David_Weber
David Weber
wich serial? Newest version have 2 switching points in seat , but if problem give always error so give serial.
  • Posted 18 May 2021 02:22
  • By tr_doctor
  • Netherlands
Regards
