Cat E3000 lift fault 61
When I change my logic card I wrote the parameters from the old unit down. When I try to load the new parameters into the logic unit for some reason they are not accepting. The DRS switch is in setup mode. I manually configured all 3 groups in the setup. Write then save. Turn the key off and turn back on. Restart the laptop and none of the parameters are saved and still have code 61. Can anyone help. Thanks in advance.
  • Posted 16 May 2021 00:33
  • By Thomas_Janolis
  • joined 16 May'21 - 2 messages
I work on Raymond stockpickers almost everyday, not sure if this will help you.
The Firmware that is currently installed in the Master Controller might not work with the Firmware that is installed into the new Logic Card.
I have had this problem occur a few times with Raymond.
  • Posted 18 May 2021 20:42
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Factory Cat MICROMAG20D
Unicarriers FHGE35T5S
