No movement, mast functions locked.
I have a Komatsu that has been sitting for a while. Just started working on it and it was working fine and then suddenly Mast lock function and exclamation point started flashing. Neutral light is flashing as well. After starting exclamation point flashes six times and just repeats. Lift will not move and mast lift functions are locked. Seat switch wiring seems to be fine and have physically checked wiring from seat switch to controller on firewall. I can manually unlock mast functions by powering solenoid. My next steps are to check the directional switch and power to the trans solenoid. Any help would greatly appreciated. Thanks
  • Posted 12 Mar 2021 11:32
  • By Matt_Cade
  • joined 12 Mar'21 - 9 messages
  • Tennessee, United States
Not 100% sure but look at the rear right side below the cabin.
  • Posted 14 Mar 2021 01:19
  • By marcb
  • joined 10 Jun'14 - 221 messages
  • ANTWERP, Belgium
Do you have any idea where main relay is located so I can check that? Thanks
  • Posted 13 Mar 2021 09:07
  • By Matt_Cade
Hello Matt, 6 times flashing is a problem with the output of the main relay.
Regards
Marcb
  • Posted 13 Mar 2021 02:09
  • By marcb
  • ANTWERP, Belgium
Terberg YT222
Hangcha FLDCXT160
Sue Tomic Sue Tomic
REPOWERTEK Inc
