Red light + slowly speed
Hello,
I have a problem with E16-02, year 2005.
When the forklift is switched on, the red light (M symbol + temperature scale) comes on and the forklift does not have the correct speed. After 5-10 minutes of driving, the light switches off and the forklift operates normally and has a normal speed.
Where could the problem be?
Thanks for the answers.
  • Posted 9 Mar 2021 00:44
  • By arminsljc
  • joined 9 Mar'21 - 5 messages
  • Slovenia
Hi,I have the same problem the display says 1,is this the left motor as you are seated looking forward and where in the motor is the temp.sensor I have found the brush inspection covers but not sure where the sensor is
  • Posted 3 Jul 2021 05:13
  • By bonzo
  • joined 20 Nov'18 - 5 messages
  • United Kingdom
Check if warm up all fan turn correct , if they short than motor heat.
Disconnect the 4p connector of pump or drive motor for check all fans turn.
2 wire of the 4p saab connector are the brush indicator and only a red light in dash, normally not drive slow if this error , only overheat motor than drive slow. connect a different temperature sensor for check
  • Posted 8 Apr 2021 04:47
  • Modified 8 Apr 2021 04:49 by poster
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Motor temp sender within the motor
On the display I should show a 1,2 or 3 to indicate what motor
  • Posted 7 Apr 2021 19:17
  • By Lindetech
  • joined 27 Mar'16 - 131 messages
  • Auckalnd, New Zealand
Modelo 335 o 386? por lo que veo es 335
  • Posted 10 Mar 2021 15:15
  • By Juan_talens
  • joined 6 Dec'20 - 14 messages
  • Spain
especialista en electronica
Linde Material Handling
TCM FD80Z7
TCM FD80Z7 1990
SMV (Konecranes) 4538CCX4
Sue Tomic Sue Tomic
