Toyota Diesel starting issues
Having issues with this 04 diesel at the shop. Myself and our diesel tech have done as much as we can think of ill start from the beginning.
Forklift had issues starting and idling.. the intake heat grid was toasted and the intake grid computer was damaged in what looked like a flood. Replaced computer and heat grid. Start to notice the denso injection pump was leaking. Pulled timing cover and behold the injection gear was advanced 3 teeth. Sent out pump and injectors to get rebuilt. Re assembled with all timing marks lined up.. Installed rebuilt injection pump and timed the pump to the standard 0.81mm with a dial gauge. Starting up with ether to bleed each fuel line and after bleeding the lines the truck is idling fine and I think im in the clear after some minor adjustments to the injection pump angle. Runs great and strong for a half hour after adjusting the idle a little. Come in this morning won't start without jump start again and won't idle. This has been a headache and a half, if anyone has any advice it would be greatly appreciated, tired of seeing this truck in my bay!!
Thanks in advance
  • Posted 18 Feb 2021 08:33
  • By Joe_G
  • joined 18 Feb'21 - 3 messages
  • Colorado, United States
Found a hardline that was hand tight out of the tank to the fuel filter. Adjusted and bled lines again. After bleeding lines idled fine. Left for break came back 20 min later and still won't start. Only thing I can think of now is to do a compression test
  • Posted 23 Feb 2021 05:01
  • By Joe_G
Thank you gonna start at the tank and make my way to the injection pump..we had replaced the fuel filter first part of our check in. Report back later today
  • Posted 20 Feb 2021 03:21
  • By Joe_G
Well you're not in too bad a shape if you had it running well after the injector pump rebuild. I'd check every fuel line from the tank just to make sure you aren't sucking air into the system. Look for cracks in the hoses and make sure the (hopefully new) fuel filter is well sealed. If you sucked air in, you'll have to bleed everything again. If bleeding makes it run again you'll at least know what's happening.
  • Posted 19 Feb 2021 13:13
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
GemOne
GemOne
