Carbon Monoxide Concerns
Are their concerns with CO levels with lp forklifts operating in a small 8500 sq ft warehouse when dock doors won't always be open during the winter? I believe that Toyota 5k lifts' CO emission are 20.8 g/kW-hr, almost 2 times it's competitors.
  • Posted 13 Dec 2020 14:27
  • By Wayne_G
  • joined 15 Nov'20 - 19 messages
Wayne
While a forklift lift contributes to CO emissions other items do too - like gas heaters. It is the concentration of CO concentration in the ambient air in the working environment you need to be concerned. Last I recall it was a max of 50 ppm per OSHA regulations - could be less today as I've been out of this business since '.07. The air exchange system ventilation system can be the difference in a pass or fail "CO" sniffer test and can vary significantly based on how full or empty the warehouse is and how long the forklift operates and other things
  • Posted 28 Jul 2022 20:03
  • By johnr_j
"Have An Exceptional Day!"
Every winter when the temperature drops in Australia people rush to switch on their central ducted gas heaters or other gas appliances. But it might be an invitation to a silent killer (CO) as it increases the potential risk of CO poisoning if the gas heater is faulty. https://ductscleaning.com.au/service/carbon-monoxide-testing-service/
  • Posted 26 Jul 2022 17:31
  • By jamesdallydally
  • joined 26 Jul'22 - 1 message
  • Norway
james
The air exchange system in the building has a lot to do with the total CO concentration in any building too plus other sources of CO emission.
Hard to believe that any brand of lift has twice as much as another brand as they all must comply to the same Tier standards - can't recall seeing this info on a spec. But right now right now many popular Toyota LP lifts shipped have zero emissions - they are all in dry dock last I heard.
  • Posted 29 Oct 2021 08:51
  • By johnr_j
IC truck emissions should always be a concern for companies that run IC trucks indoors on a consistent basis. It is up to the customer to make sure they monitor the CO levels and keep their machines maintained to insure the CO levels are kept to an acceptable level. Proper building ventilation is also a factor.
As for as which brand lift has more CO emissions versus another? As i said previously, it all depends on the maintenance and the consistency of monitoring the trucks emissions and making sure they are tuned up and CO levels kept down to a minimum. Sure, if there is a real concern about CO emissions then install CO detectors to monitor this throughout the areas effected.
  • Posted 28 Oct 2021 21:40
read and become enlightened. Found this info in less than 2 minutes via a Goggle search. The last I knew Canada adopts many of the OSHA regulations but has a hard time getting Lord Stanley's Cup North of the US border - 1993 last time as I recall - but we still appreciate having Gordie Howe in Hockey-town USA - grew up in the Motown area where we drive SOUTH to get to Canada. Ciao!
https://www.epa.gov/indoor-air-quality-iaq/carbon-monoxides-impact-indoor-air-quality
https://www.homedepot.com/p/UEi-Test-Instruments-Carbon-Monoxide-Detector-with-Alarm-CO71A/306091460?source=shoppingads&locale=en-US&&mtc=Shopping-B-F_D27L-G-D27L-027_005_FIRE_SAFETY-NA-NA-Feed-SMART-NA-NA-SAFETY_SECURITY_FireSafety_New_Engen&cm_mmc=Shopping-B-F_D27L-G-D27L-027_005_FIRE_SAFETY-NA-NA-Feed-SMART-NA-NA-SAFETY_SECURITY_FireSafety_New_Engen-71700000082263410-58700006984682162-92700062875449987&gclid=EAIaIQobChMIjLPS8Nfs8wIVxaeGCh20pQD5EAQYBCABEgKAFfD_BwE&gclsrc=aw.ds
  • Posted 28 Oct 2021 19:33
  • Modified 28 Oct 2021 19:56 by poster
  • By johnr_j
No Idea about the CO level
  • Posted 28 Sep 2021 22:02
  • By Rechird_S
  • joined 28 Sep'21 - 2 messages
Here is what OSHA states
"OSHA PEL] The current Occupational Safety and Health Administration (OSHA) permissible exposure limit (PEL) for carbon monoxide is 50 parts per million (ppm) parts of air (55 milligrams per cubic meter (mg/m(3))) as an 8-hour time-weighted average (TWA) concentration [29 CFR Table Z-1].Oct 22, 2020"
In a nut shell having a sufficient building air exchange system can help business to be in compliance no matter what the forklift lift CO out put.
Of course, all forklifts must comply to the same emissions EPA standards Tier II, III, IV since the early 2000s depending on the year of manufacture.
  • Posted 16 Jan 2021 23:16
  • By johnr_j
Aichi RX07B
Ncn 110TH
Ncn 110TH 2015
Aichi RX07B
Ncn 110TH
Ncn 110TH 2015
Sue Tomic Sue Tomic
Aichi RX07B
Ncn 110TH
Ncn 110TH 2015
