ERCO30BG SQUEEZE
11 Start switch closed before key. No forward or reverse. I suspect its a fuse. Right now im trying to locate the fuses!! The race is on to figure it out before someone tells me!!
  • Posted 20 Oct 2020 09:34
  • By Duane_Carroll
  • joined 26 Mar'20 - 16 messages
It was a stuck accelerator switch! I got it man. I appreciate the help
  • Posted 27 Oct 2020 06:18
  • By Duane_Carroll
well the 'start switch' is generally the accelerator switch.
Depends on when this unit was built and what system is in it.
Got a serial number?
  • Posted 24 Oct 2020 11:16
i changed out the accelerator microswitch. its still reading the same thing. where is a start switch??
  • Posted 24 Oct 2020 10:20
  • By Duane_Carroll
doubt it is a fuse
the error says "11 start switch closed before key" so you have a switch stuck or possibly a shorted wire/circuit.
check foot switch, brake switch.
it's probably the accelerator start switch stuck on, make sure the pedal is returning completely also.
  • Posted 21 Oct 2020 22:19
  • Modified 21 Oct 2020 22:22 by poster
MAXAM Tire, Inc.
Taylor TX330S
USD159,500
SMV (Konecranes) 12-1200B
MAXAM Tire, Inc.
